develop a solid
  • Thread starter Thread starter dddavide
dddavide
hello to everyone, can anyone tell me how to develop an open solid? I have steps to develop but I can't because a window comes out with open solid writing.... thank you very much
Hello, David,
You should try to close the solid somehow ..naturally depends on how distracted it is... :))
there is also the solid imploding command that also allows you to lower the tolerance of the model ..
Let me know if you've solved it.
soon
Matteo
Hello thank you I tried with solid implodes, but he tells me
incorrect selection: impossible to create a solid by selecting only a solid. would you even tell me if I create solids in autocad coome I can import them into thinkdesign and then be able to develop them?
thank you goodbye
Oh, oh, oh, so on two feet I wouldn't know I should see the model .. if you can send it somehow I look at it a second. .
thank you goodbye
You have to save them in a format that is kind of well accepted by thinkdesign ..
dwg for example only matters part 2d .. so you don't do anything.. you have to use the steps or iges .. if you pass for iges .. then you have to implode solid ..
test with "solid explosions" command
insert - surfaces - solid explosions
choose the surfaces that interest you and add the thickness with the "low" command
Many times I solve this.
