DrBarde
Good morning.
Unfortunately I have not found specific discussions about the subject, so I open a new one.
assumption:
in the company for which I work, when making the metal sheets, usually from 4mm, the total length of the sheet in the inner part is considered as development, as an example of the following made in 2d
problem
we are trying to reproduce the same effect in inventor, since the design has moved, rightly, to 3d. but every time the sheet is shorter than 3/5mm, and we can not understand how to solve the problem. we don't know what values to intervene, or if we miss the commands. we tried with flanges, hoppers, profiling but the result does not change on the flat model.
assumption:
problemwe are trying to reproduce the same effect in inventor, since the design has moved, rightly, to 3d. but every time the sheet is shorter than 3/5mm, and we can not understand how to solve the problem. we don't know what values to intervene, or if we miss the commands. we tried with flanges, hoppers, profiling but the result does not change on the flat model.
