development
  • Thread starter Thread starter Devis
Devis
Good morning to all, I sent here below the two parts of cone trunk that I designed, but I do not find to extrapolate the dxf for cutting. Is anyone able to give me any disappointment?? thanks in advance
you have to select the extension function between the sheet functions. select an external edge to the sheet as fixed face and click on collect all folds.
the program will generate a flat configuration that you can put on the table or use as dxf for cutting.
if you have solidworks 2010 (I don’t remember if it does also 2009) it can save the developed dxf file directly(save with name.dxf.-selections as a source an external point to the cone and you appear the dxf to be saved).
I forgot, in one of the two files you used the cut. when working with the sheets remember to activate the option "leather to the thickness". Otherwise you may not develop correctly or completely geometry. alloy to the thickness makes the cuts always normal compared to the surface.
I tried this solution that is similar to the flattened command, the command shows me the developed piece, but when I save it after the two clicks of the mouse the figure disappears and the process does not go well.
but it is not the case of extending the sheet. Starting from the solid model does it automatically by putting it in dxf/dwg.
from the "closed" part choose file > save by name, in the drop down list dxf, give all the ok of the case, choosing the options that you present in the property manager, ok final and is done. you have your beautiful 2d openable with acad.
you can also put it on the table first and then save it as dwg/dxf, but for the plates it is convenient to use that direct command from the 3d, it saves it directly on scale 1:1 (it is active only for the plates).
rather, to cut off of sghimbex that log you have to scourge just the option normal cut (alloy in thickness in this case it has nothing to do with it, otherwise the flat repetition in the 3d gives you error even if visually it seems to work.
I opened your files and the way I told you they work nicely.
Marco:smile:
blue
I never saw her
real tenchiu!!! !
thank you, I did as you told me, even if I had already run it but nothing to do, when I save, I place the dxf and I do ok in the green flag, and then disappear the image and the dxf is not there.
And yet I assure you that I have used your files that you have attached and works perfectly.
as I said I just corrected that "fly" by adding to the cut feature the option normal cut.
repackage with dxf and dwg:View attachment SVILUPPO CONI.rargreetings
Marco:smile:
Marco:smile:
Sorry. I'm not very practical in sheet metal and its work.
Sometimes the carter cmq runs away.
using the export in dxf or dwg from the 3d you can put the bending lines. but how do they know how much they have to bend?
Usually in the development put on the table comes out also the angle the bending, but here? Do I miss anything?
that export serves for example to send the files of laser cut flattened models, which reads the dwg or dxf in 2d. do not affect the bendings, and deliver them "clean" in scale 1:1 without any annotation.
I normally in addition to the cutting files I prepare the normal swx boards with also the result of the finished bent and with all the quotations and annotations that serve the construction/assembly in the workshop. even to always have 2d tables connected to models, otherwise only with dwg/dxf you lose everything.
if you think you might need to have the referral to the notes you just need to open the files created with autocad or similar and edit/add what you want.
But I don't want to go wrong (I don't use it this way), but it seems to me that in 2010 from that window you can choose even if you bring back the notes in addition to the fold lines.. I have to recheck.
Marco:smile:
