mir
Hi, I'll ask you a thermodynamic problem:
a. I have a pot warmed by a "camicia" where I have water vapor or diathermic oil (the classic bath heating).
b. of resistors heat the fluid in the "camicia"
c. My goal is to boil the liquid I have in the pot.
given the above are correct the following deductions:
1. if I use water vapor I have to work under pressure because I have to get at least 112/113 °c in my shirt
2. If I drain the water into the shirt I must consider that I must also provide energy for the change of state => if I use diathermic oil I can use lower power resistance because I do not have to change phase oil.
Am I wrong?
thank you guys for the help
Am I wrong?
