iron72
I just wanted to understand if the blocks are elements that make up the bookstores and if you what is the procedure to create a library?
any suggestions or links are ok.
I don't understand how far you know the blocks, but for clarity every block is created from scratch or you can change those downloaded from the network.I just wanted to understand if the blocks are elements that make up the bookcases... .
I'm just approached the blocks. from scratch I have seen more or less how to do while those downloaded from the network I have never modified them in blocks.I don't understand how far you know the blocks, but for clarity every block is created from scratch or you can change those downloaded from the network...
see here:I'm just approached the blocks. from scratch I have seen more or less how to do while those downloaded from the network I have never modified them in blocks.
Sorry lattu you can give me some tips on a video tutorial or even text that includes images to help me better understand the use of blocks. as autocad I use the 2007 version.
thanks to any suggestion.
