kertus
as from object you would know how to tell me the difference well so as to regulate me accordingly as soon as I have to rename something? Thank you.
It was right to understand. I assume that the instance name is the name that appears in the file model tree and filename when I access the workbook from windows. a modification of it involves losing the change in these two contexts and in all the axioms in which I used the file.In fact there is not much to understand ... the common name is an additional description than the object code, if it can serve, one can use it, otherwise ... nothing. I was curious too and I wondered what I could use it, but I practically didn't do anything about it.
exact, it is the name of the file, the main code that is then used also in the assemblies to recall the various details.... the instance name is the name that appears in the file model tree and filename
It is not possible, the instance name cannot be duplicated, it must be unique, otherwise it tells you that it already exists.... if for example I keep them all the same inside the family table ...
