rizzifrizzi
I press that I am now approaching the world of oleodynamics and until recently I was convinced that pneunatic and oleodynamic followed the same logic, that the main diff was in the greater robustness of the components and in the recovery of oil. I am noticing that they are only vaguely similar and that they can often find logical or constructive nexes.
from a few days I find myself in great difficulty to choose the right component to be mounted on the cylinder to ensure the position of the cylinder itself and its load.
confusion is fueled mainly by the fact that wherever I look for information the description of these valves is always the same
. "valves whose function is to lock the cylinder even under load etc..etc"
All right, that's what I'm looking for.
but then why do so many types exist?
leaving aside the various subdifferences (flanged or not to simple or double effect.. types of mounted springs.. ) it seems to me that the two macrofamilies which can perform this function are reduced in:
-block valves
- overcenter valves
the first certainly less sophisticated and also the encumbrances and the price they say long.
the second ones instead more complex and bulky, already from the logical scheme vien to put his hands in the hair, have adjusting screws and the cost obviously is much higher.
I hope someone who knows them well can clarify substantial differences and therefore when you need to use a type rather than the other.
-block valves
- overcenter valves
