different di taglio
  • Thread starter Thread starter Per5
Per5
Good morning to all,
I have my second problem of the day,
I would like the individual parts to cut out the single weight of each component.
in the part that I attach, consisting of two pieces of plate sp.10, obtained from cutting of the plate to the laser, I draw from the side the boundary of delimitation through the appropriate command, regarding the measures of the individual pieces all ok, also for the volume of the individual is correct.
regarding the mass instead it is always set on 0.0 and the weight item I had to insert it manually, although in the properties of the file part the weight has already been inserted, but that refers to the total part and not the individual elements.
it also inserts me into the cutting distinct other elements that in the part are not present.
I attach pictures to you, I hope I've been clear.
I follow, update, the problem I probably only have in this file, now I verify, in case I delete the discussion.
Thanks and sorry
