different elements, different results?
  • Thread starter Thread starter John
John
Hello everyone, I wanted to ask for information I have to calculate the pressure before arriving at plastic deformation (yielding point 260mpa) in this piece with the following data:
e = 200 gpa
poison's ratio=0.3
density =7860 kg/m^3
thickness = 10 mm
measurements in mmI created two models one with
solid>quad 8node 82
solidity
but the results obtained are different
in the first case arrive at 251e6 for a load of 2e7 pa
in the second case I arrive at 278e6 for a load of 2e7 pa
So I have doubts:
If I select different elements I get different results, I mean big differences (about 30 mpa)?
If I intensify mesh in critical points, i.e. in holes and fillet, should results change a lot?
thanks to those who will answer me:biggrin:
Hi, I tried to do a test with ansys wb11.
max stress is lower (141 mpa) than yours.
the mesh has been fixed (size elements 2 mm).
try to see if the constraints are correct.
Hello! !
thanks, for the answer :d...
However I forgot to specify that the parts bound to move are the other two holes, so I think the simulation changes a little.
The importance of a good mesh is so important to me that it is fundamental, because if I break the effort, it changes clearly.
solid>quad 8node 82
solidity
So I have doubts:
I once had made a simulation (apposed to check this thing) loading a bending bar, meshata with:
1) linear tetra elements
2) square tetra elements
3) Linear Exhaust Elements
4) square exaggerated elements
the difference of the sigma from 1 to 4 was also 30%. in general linear tetra elements are too rigid and should not be used for structural analysis, better tetra-quad or esa lin or quad. At least that's what my fem expert friend always tells me!
so the holes are only bound by the slots?? as in the image.
I have made a simulation with code_aster + salome, I attach the images with the results for linear mesh
Consider that I've put in the two holes, not cylindrical hinges.
questo invece per mesh quadratica
I'll give you some advice again. in these cases, in reality it never forms as solid, but as plane or as shell. I suggest you do these 2 tests first and then check the values obtained from solid modeling.
I tried to perform the analysis of your meshandolo piece by plane82 elements in tension plane and assigning it the thickness 10 mm.
by infitting mesh I got the following results:
max size element --> voltage of von mises
5 mm-- 251 mpa
2.5 mm --> 269 mpa
1.25 mm --> 276 mpa
0.625 mm...> 279 mpa
I think convergence can be assumed
