different materiali
  • Thread starter Thread starter andrea.boerio
andrea.boerio
made a bom of a joint-study (a thirty codes, between parts and subaxis), set as a table with indent and detailed numbering.
edit the columns a little, and all right here.
the table is numbered as follows:
1
1.1
1.2
1.2.1
1.7.8 as the last line.
It's okay here.
I add a particular in the axieme, in a position such that the line 2 should be born in table
except for everything, I close, I open, and I go to the table: The table is not updated.
I check in the options, and the automatic update is flagrant, so I'd expect to see the new line coming.
strange thing, then, is also the fact that if I change the properties of the table, and I make it become an explosion only of first level, the line 2 is born, idem the line relative to the new component appears even if step to an explosion only parts.
if I go back to an explosion with re-entry the table returns to have as last line the 1.7.8
we accept suggestions. . .
The tests are as follows:
1) open another set and perform the same operations.
Yeah, right?
2) try to load the incriminated axieme on another car.
Yeah, right?
3) update the sw sp.
Yeah, right?
4) rename sw registry.
Yeah, right?
in the meantime I checked something this morning (I was going to post):
on a new table the problem did not exist.
on the incriminated table, going to double-click the column to (the one containing references 1.1, 1.2, etc...) as column type appeared part number (although actually the references of the stamp were indicated!?!? I don't explain that.
cmq, reimposed on article num.,agggiorno numbering and the line with reference 2 appears.
from this moment on, if I try to set the column again on number part (to see what happens), what happens to me, i.e. the names of documents are shown (as set for default configurations).
back to set item num. and everything goes well.
I think he nailed something.
I keep cmq good references for checks in case of next strangeties.
Thanks again.
a.
