different materials at multiple levels
  • Thread starter Thread starter qui
qui
Hello, everyone.
I'm trying to set a new distinct materials on sw designs.
I can explain better:
I made a set, composed like this:
- a set (which is a soldered)
- the link between this assembly and another component (not designed. the screw+dado+ 2 washers.
Now: by making the distinction by listing the parts, sw mi "explodes" all the axis, and makes me see the right amount of screws: (e.g. 8 screws, 8 dice and 16 washers), if it explodes with re-entry it shows me the main axieme, its components, and for the screws gives me the number of times that the axieme screw is repeated, and how many screws + bolt more washer there is in each screw set.
If I put "only first level", I get 1 together, 8 axiemi screw...
Is there a way to make a distinct multi-tiers appear, but that keeps me the total quantity of the individual parts?
steak
If you want you can also manually insert a column into the separate column where you multiply the quantities present in each group by the number of occurrences of the same group present in the axieme in question (the multiplication then obviously is made by the software!).
then I don't know how robust this function is, in the sense: I do not know if the system is able to update the table in case components are added or removed from the axieme for which the rows with multiplications should move.
