different sheet thicknesses
  • Thread starter Thread starter themole
themole
good morning, I have a sheet file with internal folds with 2 external rays from 5 (the sheet thickness is 3mm) , how can I bring them to 3 interior and 6 exterior quickly? Is there a command that equals the thickness of the whole part by changing the rays automatically?
can you post the file? depends on how the model was made. If your sheet is made with the sheet metal module by modifying the sheet style in use you should solve (there is the fold radius parameter that handles this)... but if everything was done "good" (between quotes because the good of one is the evil of another) in the first should be already all equated, so I can think that there is a few meals in between. I see you indicate solidworks as your software: Are you using inventor occasionally? just to know if any explanations should be a little more detailed. . .
Bye!
by default the inventor sheet module is set for: inner radius fold=thickness.
If you want to change in toto, go to "default sheet values" click on the pencil symbol next to the "sheet rule" window,
then under the heading "piega(bend)" you find the ray box and type the internal radius you want.
I imported a step showing a thickness 3 but with internal rays from two and external 5 what to do?
If you told us before it was a step, we could give you more answers.
Type :
1) "There is nothing to do if not rebuild each chord to handle "
2) " if you have installed fusion, try with that "
Top-level software in circulation that allow every kind of manipulation on the steps by recognizing perhaps the features?
that I know solid edge allows this operation or am I wrong?
even inventor does it, more or less well.
as catafract said, if you can post the file, you hop in and you understand how you can solve it.
