difficulty setting lighting by inventor studio
  • Thread starter Thread starter alessandroM
alessandroM
Good morning
I have a problem about inventor studio: when I go to set up a lighting (in my case outdoor), I give it all the options suitable for my case, but at the moment when I save those settings and click on done, I get out of the window but I lose everything, if I want to review my illuminated set I have to go back and click again on outdoor/sun.
at the end I need this because I have to perform an animation with the illuminated axieme according to the settings assigned, but all the time I go out from lighting styles I lose the lighting, I no longer know what way to take
Can anyone help me?
thanks in advance
Thanks once again Pompey, I finally solved. now I have to understand why if I illuminate a mirror I see it all light grey and not white
depends on the settings (if the incidence of the sun is obviously grey) or how the software is used.
for example:
- You enabled the sun in style?
- You set the direction, the intensity of the sun?
- You chose a mirroring material?
- You launched the render?
I did everything you listed, only that remains the problem, I tried to go on surface styles, I managed to create a surface style of a mirroring material, but I can't apply it to my mirrors.
The result I expect is that a mirror reflects on that other
