dipting die esterni con revit 2008
  • Thread starter Thread starter sergio76
sergio76
hi to all my name is sergio di casarano (le) and I am graduating in civil ing (yes already ing of the materials) I can not change that gray horror of the external walls that by default revit architecture 2008 , I would like to give a color to my structures but dismantling a little I did not succeed, magari is a cabbage! thank you in advance. hiooo:finger:
ok, it is not very difficult, after selecting the wall on which you intend to set a new color, in the menu of the properties there is the command "modification type", you will open a screen "propriety of the type" with various parameters like "building, graphics, identity of the type etc.", under the parameter constriction there are various subparameters, the first is "structure" to the right of this subparameter there is a bar with writing
hi and good work!!! !
