directly break a polyline without using split and measure commands
  • Thread starter Thread starter karotto
karotto
Hello.
I'm breaking a polyline in points I've identified with the measured command. I'm using the command breaks at one point. Is there a faster method? is it possible to create a quick command in the pgp file to recall breaks at a point (which as you know is not a command but a macro)?
thanks for the advice that will come to me
Hello.
with divbreak you can break the poly without first using dividing or measuringhttp://www.cadforum.cz/cadforum_en/download.asp?fileid=358you can also call it back with an alias in the pgp
