directx 9 for autocade 64 bit
  • Thread starter Thread starter blubossa
blubossa
where can I find directx 9 for 64-bit autocad?
or tried to do a search on the net but I did not understand much....:confused:
bb
I don't feel like there's 64-bit directx, and anyway, "for" autocad: the most recent are available here..
I downloaded, there are a lot of zipped files and then I found a setup file that I started did the installation but autocad always crashes on the run-time directions9 and asks me the cd......
How can I solve this? ?
bb
I bet you lost your autocad cd, and your dealer can't get you a copy because it just failed, I say blubbon. . ?
trying to avoid a complaint, please, the only "legal" right I feel like giving you is the following:
win-r
%windir%\system32\restore\rstrui.exe
ok
and restore the oldest "system state" possible.
If that doesn't work, uninstall autocad, and look for another.. retailer.
go to start --> run... , and type: dxdiag, then press forward.
there is a set of information (system), below, find the version of the installed directx on your pc ... you should have the 9.0c
If you don't go here:http://www.microsoft.com/downloads/...familyid=2da43d38-db71-4c1b-bc6a-9b6652cd92a3Click on "download" and you can install them.
when using autocad use whipthread command and set value 3
the other cores of your processor should come into operation, but only 2.
I recommend.. let us know if you solve it!
Bye-bye
