disable cyclic selection symbol near object selection
  • Thread starter Thread starter cescobi
cescobi
Hello everyone
in autocad 2013 the symbol consists of two blue squares near the selection as from image.
What does it mean?
thanks early:rolleyes:
hi massive, thanks for the valuable and assiduous content on the forum, I write little but I learned so much thanks to the questions of others and your relative answers.
I find myself also this problematic, who knows that I command f I pressed by mistake this time, appears to me just that symbol alongside the pointer, but it is not that related to the cyclic selection, that is the two semi-subsequent squares, but the two squares to "bandierina" just as in photo posted by cescobi.
seems the exact symbol of "deduction constraints" but I have the function disabled and also activating or deactivating it is not removed.
What could be?
you are the symbol of constraints.
It is necessary to thank the new user that to an answer, among other things wrong because referring to the cyclical deduction, has not been worthy of giving feedback on the achievement or not of the result.
probably there are of present that you have to delete with elimivinc
I refer you to discussions about this:https://www.cad3d.it/forum1/threads/disattivare-simbolo-dei-vincoli.32527/here the commands related to the constraintshttps://knowledge.autodesk.com/it/s...18d95297-bcb0-40fb-943d-0ee94528f24c-htm.html
I don't understand why he thanked when the answer was inaccurate.
thanks to the link, in that discussion I had already passed before or after reading this, but sincerely with elimivinc I couldn't do anything, even lighting everything.
fortunately that I worked only on the improvement of a dynamic block, I noticed immediately and solved with a nice dose of well-set ctrl+z having previously saved the block.
very interesting the list of commands for the constraints of which I have never served nor have I ever had until now need, I will deepen. :
thanks for the answer and good continuation.
