disable server collaboration
  • Thread starter Thread starter kubbah
kubbah
Hi, I accidentally activated the collaboration on the serve, ie every time I save I have to synchronize with the central file on the server of my study.
I would like to ask coem to turn off qussta option and work only on the local file and "disconnect" my file from the server
when you open the project, in the inestra you use to browse and reach the folder and the rvt file to open, find in the bottom left the "stop from the central". then save the file
the problem and that when I open so, popping up on "detach from central" and then save with a new name, the save button becomes griggio and incliccabile, despite I made some changes, instead the sync button is active... .
so actually my file still depends on a central.. . ♪
How do I completely unplug myself?
