disable the animation of the sketch window
  • Thread starter Thread starter summer3d
summer3d
Is there a possibility to block the sketch window while changing the odds of a geometry?
proe every time I try to change a quota while I zoomed on a geometry will focus simultaneously on the overallity of the sketch...grrrr:angry:....
I tried to set up on "no" "sketcher_animated_modify" but nothing changes...help
strange; I also had the same need. . .
it is enough to insert in the config.pro the stinga:
sketchy_animated_modify no
and everything has settled
even in my case the setting of the variable on "no" did not solve the problem
I entered the string: I do not solve the problem, let's say it improves a bit because the regeneration of the section and therefore its removal from my zoommata takes place more slowly.
cmq I have to set it on yes, because to set it on no happens that the removal is immediate.
Thank you very much
Thank you very much
in wf2 there must be a different option, because in wf4 it works.
try looking for all options with *sketch*
