disabled mechanical
  • Thread starter Thread starter marcosan74
marcosan74
Hi guys, I'm rotten and I'm new in this community.
I'm writing because since yesterday I found myself in the m... after importing a mechanical iges file.
in the order made me disappear like that to open files and I have to thank you because I found the solution thanks to you.
Unfortunately reopening mechanical made me disappear all settaggio (icone) and in re-set them patiently I realized that I only have autocad and no more those of mechanical.
Someone would be so kind to help me.
click with the dx button on any bar you get out a small workspace active menu and choose autocad mec default.
or type workspace and then choose settings, enter to which, and choose as above.
or type dirtly to which and always choose as above.
p.s.
suggestion, once you have put everything back in place saved your personal workspace, so in case it happens again you can call it back.
p.s.
Thanks for the answer, but I realize only now that the problem is worse than I thought:
- opens me only autocad 2009 and not mechanical
- also entering where I can only see acad commands and voult commands
as if it were gone mechanically:-(
but excuse, before opening a dwg (from the win window) click dx and click on it.
then choose open with and go on the mechanical, not forgetting to flag the option always open with.........
And then tell us how it goes...
hello, first of all thank you for your prompt response.
I tried dx key and open it with, but it only shows me autocad dwg launcher and autocad application.
when I open the design with autocad application, it shows me the initial screen of mechanical but then open the design does not give me the commands of mech
I'm practically in the poop.
I must have created a big mess
Please... But I doubt that an iges import has created this mess alone. :
I don't know what else to tell you right now... .
except
1) Autocad launch normally
2) type which by keyboard
3) is there any reference to the mech or not in the left window?
