"disassemble" to multibody part
  • Thread starter Thread starter paolino
paolino
Hello, everyone! I ask advice for the following problem:
open with sw a step file containing more solid objects. I find myself with a multibody part file with indicated in the tree the different imported solid bodies.
Is there any way to "export" one of these imported solid bodies into a side file, without any connection to the starting multibody file?
(in practice: I would like to get a file like what I would get by opening a step file containing only one solid body)
I hope to be explained, thank you in advance to those who will give me a suggestion... hello!
Palo
You could save a copy of the part, select all other bodies and delete them.
He had come to mind to me too... I was wondering if there was any less slender way in case you wanted to disassemble together with many parts.. .
thanks to the suggestion, hello
a latra is to extract the bodies and then block external references, but the first is cleaner.
hi paolino, I don't understand if you want to move from multibody to a series of untied parts: to do so just click on each body in the feauture manager and do "save body".
If you want to export a unique monobody part, you have to use the merge commands and you will get a unique solid.
