disattivate command
MARCOC
Hello everyone
1616856332698.pngI've been trying to open the sheets lately, where the corner drain command is off, and it's not possible to use it. Can you fix it? ? ?
are definitely files created with versions of old solidworks, but open and restored with 2017
What do you mean? ? I modeled them but they are made with the commands of sheet metal
today place a file that from that problem
hello wintel... did you manage to take a look at the file? ? ?
or who else can give an answer to why the command is disabled? ? ?
in the example that you have attached the sheet is created by a line, try to remake it starting from the design of a face.. .1618213513858.webp
I try, but if the solution were to give it back. . then I let it go because it would have to reshape and re-start everything
