display bending axles with flanges
  • Thread starter Thread starter Rael84
Rael84
Hello everyone,
I would have the need to display on table the bending boards of a component that I folded with the feature "flangia". Unfortunately, when I use the "piatto" feature, I don't have any problems, but in this case I must necessarily (maybe) use the "flangia". Do you know a solution to my problem? Thank you all!
probably use wf3, because in later versions the problem has been solved.
When this "resolve" inconvenience happened to me by hand inserting an axis into the inner surface of the bending radius, the bending quota is quite precise. I don't know if there's a better system.
I didn't understand the question, do you need to display them in the table with the configuration of the folded piece?
If so there is no problem, just use the show/hide command.
Exactly, I use the wf3... what references do you take to build the axis?
