display divisions of a line
  • Thread starter Thread starter icione
icione
Hello everyone
use autocad 2008
on a planimetry I want to get the display (through the appropriate pdmode and pdisize points) of the perimeter division through a block (length line 1 unit), the division I get, but I would also like that automatically generated, through markers (that are not the usual broken lines) the display of the divisions carried out. (especially I would like every division to be marked from one point)
Mauritius
I did not understand, if the division you get already, then you also have the marker, which is the block you used to divide the line (block that can be composed of one point)!
I use autocad 2011 in English and I have a similar problem- at least I think.
I can divide a line into "n" equal segments through the _divid command, but the points so obtained do not react to the snaps.
I do not manage to pass for example a new line for one of the points so obtained.
What do you have to do to activate the snap?
