display flexible parts in the mechanism module
  • Thread starter Thread starter Faggy
Faggy
Hello everyone, someone can tell me if you can view the modified status of a flexible rendered part, in the module mechanism wf3, during a position analysis?
ie; can you create a video showing a spring that compresses in the mechanism?
when you redefine a part together and make it flexible, in the "variable elements" window at the top right there is an icon: "Include mechanism operation."
in one case I do not see the flexible part in the mechanism.
In the other, I see the spring in the mechanism but it does not compress, it only regenerates if I go out and return to the standard module.
enter this folder which is located in the main folder of pro-e installation:
c:\ptc\wf4\demos\demo\mdx\tutorial3
open the axieme and go on the mechanism and launch the analysis and you will see.
Good:
that example shows a spring performed inside the mechanism.
in fact in the standard module there is no spring part.
so I will exclude the display of my flexible springs in the mechanism and define them new with that technique.
so I will find in the drw the soft parts perfectly represented and so also in the film of cinematism.
Thank you very much. :finger:
