display in inventor mass both in kg and pounds
  • Thread starter Thread starter GiacomoSim
GiacomoSim
Good morning. on a project that I will begin I would like to indicate in the cartiglio (or even outside the cartiglio) the mass of the structures in question both in kg and in pounds. is this possible? I wanted to solve this with an expression, ilogic, etc. using the mass parameter in kg transforming it with a formula in lb. But I couldn't. if someone will have the goodness of a suggestion I would be happy with. Thank you.
here is an example on how to make the "map" in multiple weight units with ionps.: you are in the wrong session of the forum....you should ask a moderator to move the conversation to the correct session.
