flowingseason
hi raga are new to this forum, I write you because I have a small problem with arcgis 9.3 and a dwg file. I will explain briefly the problem hoping to be as clear as possible. I imported inside arcgis a dwg file with xrif external references (in a few words recalls all sheets of a ctr of a given area) but unfortunately when it matters does not display the quota values of the various isoipse, and the toponyms. I tried to turn all layers on the annotation item, but unfortunately this voice only works on the text created within this dwg and not dwg that recalls as external references. How can I do to make the quotas appear without obviously having to load the tablet individually, since so I would lose all the work previously done?
I hope you can help me, thank you in advance for your availability and kindness.
Angel
Angel
