display not perfectly orthogonal
fidippide
Good morning, I draw simple geometries with catia v5r19 I realized that the view is not exactly orthogonal. I better explain: if I design a simple circular section cable cylinder and put myself in the orthogonal view at the base, I see the cylinder shrink, I see the inner surface. how can I do to remove this effect and return to the view perfectly in orthogonal projection? Thank you very much.
