display of two reference systems
  • Thread starter Thread starter Alex_123
Alex_123
Good morning.
I'm a mechanical engineer with a creo. I have experience with catia v5 (1 year, management large assemblies)
I have a set with many parts and relative reference systems in sight, one for each part. I would like to hide the reference systems of the parts and to show only two reference systems of two parts that interest me.
if I hide all the reference systems by removing the check to '' sisco visualization''' and then try to make the reference systems appear of the two parts by going with a dx key on the ref. sist. of the part (in the tree) and clicking on exhibition/hiding (as I would do with catia v5), the two mentioned reference systems remain hidden.
I hope I've been clear.
thanks in advance,
cordial greetings.
alessandro
You should use levels.
create a level where you insert all the syscos you want to hide, and then impose it hidden; So you should only see the syscos that interest you.
Good morning and thank you very much.
I don't know how much it takes to insert all syscos (being a hundred) into a given level. But I will see to try, thank you;)
Have a good day.
hi, besides what proposed by @alnerviani, in the creo installation directory, in
\common files\creo_standards\templates
find a "start_assembly_mmks.asm" file in which the csys levels are managed in a distinct way between together and part.
Moreover, in the axieme, there is a csys level managed with rule.
see if it can help you understand how it works.
