display problem together at table
INVENTORMUSTDIE
Good morning to all, I have a visualization problem when I go to make the table of a set. in practice only a few elements of the axieme are displayed in the views and I cannot understand why. the problem began passing to inv2014 and I found it only on a particular set. What can I do? thanks to your time
Do you have hidden elements? or indicated as "phantom" in distinct?
in distinct components I had some subaxes indicated as "reference", but also bringing them back to "normal" the table does not change, I always give these partial views.
check if you have some "referral" or have non-solid components but made in surfaces ..
also check that the "association" option of the view has come out (something else on the right of the view page). .
Big woows!
the table now is ok! I have set all the individual elements of the distinct on "normal" and "associative" popped on each single view.
thanks to all for courtesy and availability. Hi.
