or set the template you already use as default template.Hi.
definitely the default template you use is set with that type of display
just do a new part with the template you use, set the view as you prefer and save the file as part template (.prtdot) replacing the original one
to the next conversion you should have set them as you want
I hope it's useful
tried, but the result is the same.Hi.
try drawing a solid from the template
set the display mode as you best believe
then erase the solid, the sketch and everything....practicing clean it up
and then go up the template
because the template you use to convert the imported and is not the same as the one used to create the parts.tried, but the result is the same.
on the parts I create from scratch the problem does not arise.
only on those imported from the steps.
i was hesitant to try your solution because this is an unresolved problem. surprisingly it worked for me. many thanks.Hi.
try drawing a solid from the template connections gameset the display mode as you best believe
thank you for the answer, but I had already tried and nothing to do.i was hesitant to try your solution because this is an unresolved problem. surprisingly it worked for me. many thanks.
