display welded assembly material
  • Thread starter Thread starter rubo825
rubo825
... I have another question.. .
How do I apply a material to a welded set?? when I go into property and then physical I can't change the material table (which I can do with the individual components..). the problem is that I have a paper that takes the material from the 3d file and can't change it. .
How do I apply a material to a welded set? ?
in the welded assembly go to "size " --> editor styles and standards --> choose the material you want to use --> in the dx part of the window snacks " uses as welding material " --> done --> save --> hi.
I move the discussion with a more focused title.
I tried... I just popped up the material that I care about, but there's no way.. remains always set "welded aluminium-6061". help!:confused:
if, in the material sheet or in the iproperty, select the material you want, must appear that.
sends a screenshot of the material card.
I attached you two screenshots, the material library and the iproperty library. .
For me what I see is normal, that's right.
try to put your welded in a fictitious set, generate the distinct and go to change the material itself.
I'll attach you a few screenshots, they're from rel 2009, but they should clear this up.
I tried to insert the weld into a fictitious set and I generated the distinct. the problem is that the column of the material does not appear to me.. I also tried to add it but it doesn't make me do it... Couldn't there be something stuck? not yes.:confused:
I can't give you any further indications.
If you want and you can send me a p&go, I'm here and I'm watching you.
Bye.
