dissecting part of the aid
  • Thread starter Thread starter aerox
aerox
hello to all, is there a possibility in the table to put a set of which only certain parts are dissected while the rest is not?
I tried, but it doesn't work... I go into the axieme, I create a sezx, I use the "part"-"plan"-"single" settings: I select the part of the axieme that interests me, I select a plan of assembly that I have already prepared and do ok.
the result is that in the 3d model I can not reproduce the view with the sectioned part but I only see the sampling, while in the table if I use this sezx I get that the rest of the model is no longer displayed. .:frown:
I didn't understand very well... to bind an image... .
cmq when you go to define the sample (click 2 times left above the sample) you can decide whether to dissect the details or exclude them from the section itself.
You've enlightened me, now I've seen that in the sample menu there's "exclude", of course, but the commands are not well collected I would say!
thank you so much you saved me because for tomorrow I had to finish that blessed design:-) thank you very much
if you know them is not a problem.. .
slowly you will see that you will find everything!
Thank you so much, I just finished and the result is more than good to be a beginner!!! I would post an image if I had drawing rights 2d :p
Good Sunday:-)
ps. Are there any standar cards to be inserted? I don't have to compile them or put variables, it would be just to make presence, I can set the sheet format and scale but I'm afraid I have to create a format file and make a "hand" folder to use, if it's so he scales with the sheet format or I have to make one for every size a4 a3 etc?
If you click 2 times left on the dimen value below in the table put sheet, you can upload the system formats.
I sent you an mp.
