ariete Guest Apr 30, 2011 #1 hi I performed several holes on a plate, I wanted to know if there is any function that automatically makes me the same distance between them Hello and thank you
sampom Guest Apr 30, 2011 #2 ariete said: hi I performed several holes on a plate, I wanted to know if there is any function that automatically makes me the same distance between them Hello and thank you Click to expand... If you follow a fairly "regular" scheme you could only make one and all the others with a repetition. or in the sketch phase you can connect quotas, use equations and use constraints (but this always). do the program tutorials and follow the help and guide online, it's all explained. greetings Mar
