TECNOMODEL
I am so rinco either it is not possible to measure the distance between an element (line, face, silhouette) and a work plan?
He wasn't active, thank you very much.the only case in which it may not select the work plan is that it is not active and is completely empty, otherwise it is sufficient that it is active or that it has within it a line of geometry or construction and the remote control in the direction should work
