distinct base managed by simplified representations
  • Thread starter Thread starter Daniele-san
Daniele-san
Good morning to all,
I wanted to know if it was possible to create custom axiemi lists managed by simplified representations I take the structure of the axieme below:
together father "x" contains:
1. together "a"
2. together "b"
the axieme "a" contains:
1. part "a1" (managed by ft)
2. part "a2"
the axieme "b" contains:
1. part "b1"
2. part "b2"
the assieme father "x" has a drw with all the simplified rapprs inserted in each sheet
so I would like, if possible, to create a list table parts and possibly a bubble for each of them
Can you do that?
good day and good work to all!
the system is good if the assemblies are not composed of many details, otherwise it is difficult to maintain. I prefer to make separate assemblies. as it emerged in other discussions, sometimes the distinct ones managed with this system do not automatically update and need to recreate them. It's a very comfortable system, but to keep it under control.
bye dani-3d
the parts and subaxis are those listed and not more than those.
Can you give me a tip on the table and its settings?
If the parts are so few you should not have probemes.
There are no strange settings once you have activated the rapp.sempl. you can use your usual tables.
I usually use the table that I attach to you,
but I have noticed that despite being set the respective simplified representations, it indicates values on non-truth quantities.
if I do not issue then I should indicate in the generic of the parts managed by ft the relationship (in my case).... sap_code = rel_model_name
Are they off the road?
with wf5 I can't open it
test with table > region repetiz. > model/rap and recharge the model (always with wf5)
... then I should indicate in the generic of the parts managed by ft the relationship (in my case).... sap_code = rel_model_name
ok
Okay.
Unfortunately it does not go, I have followed step by step your indications I would not have committed caxxate or is the table that is structured not in the right way
you place an image of the table
You read a little bad, but it seems good. Either way, I'll get you a table of mine... try it.
bye dani-3d
The table you posted has the same effect as mine, but it stops at the first level..that is:
1. together "a"
2. together "b"
does not take into account everything else (see below) much less than simplified representation
2. part "a2"
1. part "b1"
2. part "b2"
Hello, dani-3d,
I just did some evidence and now I've got the full list.
I still have a doubt and a question.
I have 4 sheets of the table in each sheet I have a simplified rappr
I always see the description and name of the first model (before simplified rappr) that I have inserted
are there particular relationships to be inserted?
... in each respective cartiglio always appears to me the description and name of the first model (first simplified rappr ...
It is right that he behaves like this, because with rap.simpl. you can't change code and description, the set is unique. try to manage the 2 parameters with an ft.
Good morning.
I hook up to the discussion to ask for this information: once obtained several distinct representations related to as many simplified representations and tabled on the table (one for each version of the product you are drawing) how it is possible to export every single table outside the environment so that the information undergo a subsequent processing by a pdm?
Bye-bye.
you can export tables by saving them as text files, .txt or .csv. in both cases it is necessary to "clean" them a little to be imported.
Good morning and thanks for the ready match.
I would need an indication on how to carry out this export; I looked for the options available in the table management menu but I can't find any function.
the version of creo in use is the 2.0 build m090, maybe it's too old version?
in the table menu there is the save command as a table, which activates once a table is selected.
