distinct cutting problem
  • Thread starter Thread starter enriazzo99
enriazzo99
Good morning to all, today I presented myself a problem that I never had in the separate cut.
I insert a part in another part so making it become a multibody art, and so far everything ok. if I mirror the part inserted he creates me another body other than the initial one that instead is exactly the same body (photo attached).
Thank you very much for the answer.
look that it is correct what makes solidworks. two bodies with the same name cannot exist, so two equal bodies are differentiated in the name.
if you have a sequence derived from the same fiction you will have the namecorpe_numer (or something similar), if instead you have more equal bodies derived from different functions you will have the name linked to the function.
you have a body made from a mirror so the new body takes the name from this function.
What is different is grouping in folders that include all the same bodies.
Thank you very much for the answer, now I understand. would you be able to explain in short terms the grouping in folders you mentioned?
because I imagine you'll understand it, but what I want to do is that the two flanges go in separate with one voice and quantity: 2
to have a separate cut, which is different from a distinct material, you must have grouping in folders
launch the welding command and get the folders
Thank you so much, stupidly I didn't think the function of welding centered with the distinct. I got it.
