giuseppe250388
hello to all, I have a problem with the distinct base of materials, I make a brief introduction to make the problem understand.
I have recently joined a new company that deals with equipment of vehicles with cranes etc..., the company is going through a transitional phase and switch to a management that also takes care of the management of materials of the carpentry. the management to manage everything needs distinct bases to be inserted inside.
from what I understand, I am not an expert in management, the most important information I have to pass is: codes of every single together; the codes of each particular that make up the axieme and in addition a code that I call id (1,2,3,....n; 1.1,1.2,1.3,...n; 1.1.1,1.1.2,1.1.3,...n)
Now I'll explain how I'm going when I make a project: I realize a particular, then I go into options and there I insert a description in the nomenclature part, then I insert a mass-type parameter and a string-type parameter that I will call raw cod.materie and fill it with the material code for the purchase, I close everything and save.
and so I continue for all the details that make up the axieme, I insert all the components in a design assembly, to completed project I go to customize the distinct base inserting what I care about and then save in excel format...
Here I come to the core of the problem, when I see the distinct base I realize that the program while making a distinction between fathers and children etc. not assigns him an id code (but only the code of assemblies and parts), I realized, and on this I have to thank the forum, that there is also another possibility to pull out a distinct and and that to save in assembly design directly in txt format, surely it is a more synthetic but immediately gives you the idea of fathers and children, but not even there and inserted an id...
I make a small example just to be clearer
1. code together
1.1. Special code
1.2. Special code
1.3. Special code
2. code together
2.1. Special code
2.2. code together
2.2.1. Special code
have you encountered similar problems? how do you manage these operations?
I apologize, trying to explain myself in the best possible way, I've been a little too long.
1. code together
1.1. Special code
1.2. Special code
1.3. Special code
2. code together
2.1. Special code
2.2. code together
2.2.1. Special code
