lukaluk11 Guest Jul 8, 2009 #1 Would someone know how to display the separate components on the table with reference on the components? I thank early for the help.
SweptBlend Guest Jul 9, 2009 #2 Usually a table with the parameters used in the part (code type/description/ etc.etc. ) and insert the board, the command creates bubble. usually tables are already created by companies (with the required parameters) percu are only to be inserted by table / insert table /table from file
re_solidworks Guest Jul 9, 2009 #4 if you have to create it from 0 you have to make an empty table, add the simple repetition region and then insert the strings that recall the parameters.
