do not print render in the tables
  • Thread starter Thread starter emassetti
emassetti
Hello my name is enrico and I am new,
I work with revit 2010 and I have a problem with the printing of renders that save in the drawing, I put them in the table but at the time of the press I do not print them, I do not even see them in the preview.
This doesn't happen to me if I amount an image from outside.
thanks to all in advance
fast sunshine:
sava the renders, even in an external folder, and then reimport them to the tables
correct solution:
... maybe, dpi of rendering too high...
... some incorrect setting...
I saved them in the project to maintain the graphic scale, wanting them to use as prospectuses.
I tried to change some printer settings and now it seems to work.
Hello, emassetti.
I am more than convinced that it depends on the type of processing set on your printer. printers and plotters usually have (in print properties) the ability to specify on the pc the processing of the printing process. in this way do not "saturate" the memory of the print device and avoid problems.
