does not work model scale
  • Thread starter Thread starter silvia leoni
silvia leoni
Good morning, I saw the discussions in which we were talking about climbing a model and I also saw in the creo guide, but I still can't climb. by premitting that I had to insert the units of mine in meters instead of mm (for a density calculation problem), I should scale a geometry copy to which I applied the thickness command. I followed all the steps but it makes me mistake, can someone please help me?
1632814188290.webp1632814270160.webp1632814287465.webpand if I try to insert a value I, type 3 (which though would be 1.5 m... instead the model is often 5 cm, 80 cm tall and 70 cm wide) this happens 1632814403068.webp
behavior is correct because you are tending to scale a geometry that is linked to another model through copy geometry. to do it freely you have to break that bond.
Bye.
But... I use it to apply the withdrawal, for 1% I have to write 1.01, you are applying 0.01 which is very small therefore likely to go into crasc because it cannot create very small entities.
However, as stated before by prof., you must unleash your part from the copied surfaces because in regeneration you will always find surfaces identical to those of the reference model.
the suitable command is not "scale model" but applies withdrawal which however is in a specific package.
