does nx import stl format?
  • Thread starter Thread starter mariuss.r
mariuss.r
Good day to all
I would point out that a search on the forum did not give me any results.
I should send my client an optical scan for his verification.
my question is: does the stl format matter?
and if the answer is positive: is it possible to draw in nx sections on the stl or project curves?
a thank you to those who will answer:smile:
Good day to all
you can import the sl and you can also do the other two operations you ask as long as you remove the associative flag on the commands.
you can also create a surface from the sl but with a separate module.
Thank you for your answer!:smile:
for the surfaces there is also the rapid surfacing command, which should be in the cad "base"
My colleague who has the basic module is back today and the command is not there. I think fast surfacing takes the mach3.
