door position
  • Thread starter Thread starter axelscorpio
axelscorpio
I have a problem quite simple as important. I have a wall of 80 cm and a door of 160 (2 doors). insert it more than easy, but it always puts it on the wrong thread, that of opening. I practically keeping the opening in that sense though I would like to have the door on the inner wire so that the two doors remain inside the wall.. possible that you can not set if you have the door on the inner wire, external, or in half-wall?
It happened to me once and I did so: try to divide that wall from 80 cm to the point where you have the door and create a narrower one (e.g. 10 cm) on the outer wire. to put the door on the ten wall. automatically the door returns. I solve this, but specifically your case I don't know... try.
