"double" flexibility
  • Thread starter Thread starter tartufon80
tartufon80
Hello everyone!
in a management component with flexibility both a quota and a parameter: or rather, my intention would be to change the description of the "generic" part (at deactivated flexibility), once the value of the flexible quota is set.
e.g. :
my part is a ø20 6000 length tube with description (which is my parameter): pipe ø20.
Now, I would like that when I impose the flexibility of the length quota (eg 200), automatically the description parameter, also managed in the window "flexibility", becomes tube ø20 l200. I don't know if this should be handled with relationships... .
At the moment I am encountering some difficulties.
Thank you!
greetings:
try to put this formula in the reports description=description+itos(length), I'm not sure of the result because I've never verified it with flexible components, in theory it should work.... try and let me know.
only defect is that in subsequent regeneration continues to add the previous description to the new
I solved by creating a text parameter
description=testo+itos(length)
so it only varies length
You could tell me where I find the meaning of the functions found in the relationships.
besides the trigonometrics there are some that I do not know (as itos )
Yes, yes, good, however the important thing is that the game works.
consult online help looking for operators or functions
thus proves relations
quade the attached files.
if you want to change the length of the hose,
go together and change the "length" parameter of the hose component, not the flexible part.
flexibility follows this parameter and the relationship for description and also on this component.
and good weekend!
hinges
and good weekend!
hinges
thank you all!
the solution proposed by dani and then corrected by Lionizer I have already adopted it, but the thing is complicated if, as in my case (and I forgot to tell you before), it has to do with family table components: I should manage a support parameter for each variant....cmq is a road.
the solution proposed by winters seems to change the original description. ....
the example posted by arni Instead it seems to work, only it is made with wf4; my file is made with wf3, but I can't replicate the thing. I have not understood your explanation: "go together and change the "length" parameter of the hose component, not the flexible part.
If you don't have trouble, could you be more "clear" (for me of course:redface:)?
Thank you very much!
