double weight on imported models
deep70
Hello everyone,
I realized that in the table of a particular data imported from *stp and then turned into sheet metal, the weight on the cartiglio seemed to me to be double, as if the system counted the original stp model as well as that turned into sheet metal.
how should I proceed to display the correct weight?
as usual I thank everyone in advance for the kind answers given.
In fact, in the cut you have 2 elements. It's beautiful.
If you have turned the step into sheet metal, this should not happen. if you attach the file who has 20xx solidworks could tell you where you were wrong.
by doing the image autopsy and re-creating in the laboratory functions I confirm that using the sheet metal convert function to transform a step does not transform the solid body but creates another one with the result of having two bodies, using the insert folds function instead transforms the solid existing body into sheet metal
as always you are perfectly right!
thanks massivonweizen!!
clarification:
you can also use the convert sheet function, but you have to remove the check to the option keep the body. read point 4 of the guidehttp://help.solidworks.com/2015/italian/solidworks/sldworks/t_solid_to_sheet_metal.htm[/quote
perfect boulders, at least it will be enough to remove the tick to correct the problem, already I was worrying in fact on how to proceed, I was afraid to have to remake the others. less bad you and solidworks always number one.
Hello and thank you again.
I add another detail though.. you have me once you remove the check on "hold the body" I no longer see the flat breakdown in the table.
place a copy of the files.
verify the two default configurations and default development that have the flat repeat function set correctly. suspended in the first and active in the second.
since it does not seem that the odds are released verify that in the default development configuration the body is visible both in the part and in the table
Fixed Mass, in fact it was to set up the configuration! !
thanks again and hello
