doubt technical design symbol
  • Thread starter Thread starter archguida
archguida
hello to all, I happen a mechanical design with this symbol next to a threaded hole, I think it is the depth of the hole, what do you think?
It should not....it is certainly the symbol that has become international that indicates depth.
solidworks has used it native for many years. others have adapted.
6 is the useful depth of the thread.I confirm that the symbol has now been unified by default.
Good morning, does the symbol indicate the useful depth of thread or pre-forum? is it reported to some regulations the above symbol? Thank you.
work in uk and here we use quotation the thread and its depth(blue) then quoti the foreskin(red).
1716891015886.webpThe standard is bs8888 if I remember well.
thank you so much for the answer but it doesn't work vertically? . You know that fugue, too.
I never tried, but once I thought of drawing with the sheet vertically but with the horizontal layout.. I don't know if I explained. ..practically create a vertical a4 sheet. but having both situations in a table I don't think it's possible.
if it is not possible/turned to quota the hole in saw section, it is seen in the plant and inserting elements from the model/function you check the punctuation caption box, so doing exits that symbol both for the depth of the foreskin and the thread.
is convenient to avoid adding views to the sole purpose of quotating the threaded or laminated hole.
