doubts about categories and lines
  • Thread starter Thread starter Marcogeo
Marcogeo
So, I take a brief premise.
I have always been accustomed to drawing using the real thickness of the lines, therefore in 0.3 for sections, 0.1 brochures etc etc etc.
I think I created a wrong model at first in setting categories. I had not actually attributed the correct thickness therefore drawing a wall, for example, this came with the thickness 0.05. I made the change through attributes. then I corrected the thickness in the categories and it happened that in the technical views of the prospects instead of having the thickness of "0,1" I always found 0.3 for what concerns the walls.
I have seen that you can correct something by climbing the thickness of the lines from the viewports but I do not think that is the solution.
Regardless of what I did, how do you behave?
edit categories by attributing them the right thicknesses.
verify that objects belonging to the categories are assigned in the palette of the thickness and color attributes of the categories (there is a black dart indicating it).
in viewport attributes you should automatically update unless you have edited the categories of viewports by assigning them different attributes. in that case you can reset to the starting settings or edit the individual classes.
I do.
I do.
but in the technical views of the prospectus how do the thicknesses of the lines appear?
Thank you very much and I'm sorry for the continual disturbance.
So, are you talking about viewports or drawing layer?
anyway I see the thicknesses as well as I set them up.
If I then create viewports in different scales than the design layer, I will edit the categories of viewports to adapt the thicknesses to the change of scale.
I do.
I know I'm messing up and I apologize.
I'll tell you what I'm doing. I basically gave attributes through categories. high/plant view is correct but if I go into perspective or isometric views the attributes remain unchanged.from here, if I have to go to the press, how do I give it the correct attributes?I mean, a wall in the plant will have line thickness 0,30 but in the prospect it will have to be 0.10. Where do I miss?
It happens to me, another problem. I made the parapet on the terrace. the parapet is superseded by the supper that lets see what is below and its structure even if I give it a filling.
Now I try to vary the method of construction to see if I delete the display defect, otherwise I am forced to make it invisible in the view.
  • Vista alto:pianta.webp
I get it now.
You have to create viewports.
one for the view in the plant where it keeps the thicknesses 0.3.
the other of the prospects that he edits and checks on the walls and other elements no longer saw the thickness 0.1.
I do.
I get it now.
I do.
explain to me better, is it a generic viewport setting (reachable as?) or should I edit the viewport itself (after double click, select everything and give attribute)?
Is there a possibility to discriminate against objects seen in section from those in the prospectus? For example, in domuscad, I describe in the construction phase that the walls below a certain height I must have different thickness than those that have greater height.
relative to the problem placed on the visibility of objects (in the attached file see the top) placed below others on different categories, what do you think?
when you create a viewport in the info shovel you can change the display of the drawing portion contained in it. see there is a button to edit categories that lets you access a window. from there select the categories you want to change and change their attributes.
but this change is applied only to the selected viewport. on the design layer will not change anything, as well as in the other viewports as long as you don't edit them.
I don't know domuscad so I don't know what you refer to exactly. but on vw to differentiate the thickness of the objects or create them on different classes or edit them by changing their attributes individually; even if belonging to the same class they will appear of different thickness.
I do.
I mean that if you make a wall h=270 and from this you start a wall h=100 the wall you will see it in front of the highest wall that instead will appear dissected.
In practice I can set the section planimetric line.
I'm going to try to make your statement.
I know that in a few minutes, with all the trouble you take (because I give it to you, well understood!) we arrive at the payment level dinner! :
I do.
I solved it! it's a little hard to process everything but the overall result is of great level.
Bad experience.
I made an initial model like me and saved it. so I use the categories with the attributes I chose. as we well know when using category attributes this is highlighted with the dart in the palette. Now, I wanted to remove the attributes to make a test. the mac shakes a few seconds and vw closes!
What can that be?
