alessioddd
Hello everyone!
I wanted to ask you this problem that I found: the table of a part or together, created in inventor, and saved in dwg through the export command or the command saves by name, I cannot use it on draftsight. the file is properly opened but it is totally empty. Can someone tell me why and if there are methods to solve this problem that is not to use autocad??? Thank you.
