draft of families of parts
  • Thread starter Thread starter sps
sps
Excuse me.
I'm new on the forum and I'm just using it.
I would like to know if it is possible to generate draft of models generated as families of automatic parts:biggrin:,
or if you can have a draft with quotas indicating parameters then marked in a table on the drawing, of all models generated:cool:.
How do you do:mixed:?
:frown:
Excuse me.
:frown:
you can do the part family table, but if I remember well it is a command that was introduced with the v20. There is also a tutorial about it.
with v19 (but also with other versions ):
to make the drawings instead you could use the quick templates, i.e. create the drawing for the first piece, save it as a quick template and then use it as a start for the sucessive designs. if the pieces then are very similar, you could (when you created the first drawing) save it by name and connect it to the second model and so on for all the models created.
