Xythras
hello to all, I tried to upgrade draftsight in the x64 version, from v1r4 to v1r5 unfortunately the procedure has stopped because from what I understood the uninstallation of v1r4 does not go well.
the result was that now I have no version worked, although in reality no modification should have been made to the system, because of the v1r4 in looking for the .msi file it is told that on tip to a location not available.
Since I was very well with this software I would like to know if you have suggestions, I also tried to untie from control panel, but also so the process stops.
if I try to restart the installation it interrupts with error code 1721, the operating system is windows 7 64 bit updated to the latest version.
